Zum Hauptinhalt wechseln
HP Spectre 13-4002dx Touchpad Replacement
Was du brauchst
  1. HP Spectre 13-4002dx Touchpad Replacement, Bottom Case: Schritt 1, Bild 1 von 2 HP Spectre 13-4002dx Touchpad Replacement, Bottom Case: Schritt 1, Bild 2 von 2
    • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
  2. HP Spectre 13-4002dx Touchpad Replacement: Schritt 2, Bild 1 von 2 HP Spectre 13-4002dx Touchpad Replacement: Schritt 2, Bild 2 von 2
    • Pry up one corner of the bottom case with a spudger.
    • Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Remove the bottom case.
  3. HP Spectre 13-4002dx Touchpad Replacement, Battery: Schritt 3, Bild 1 von 3 HP Spectre 13-4002dx Touchpad Replacement, Battery: Schritt 3, Bild 2 von 3 HP Spectre 13-4002dx Touchpad Replacement, Battery: Schritt 3, Bild 3 von 3
    • Orient the laptop the same way as the pictures. The battery is bordered in a red outline.
    • Remove the six 4 mm screws using a Phillips #000 screwdriver.
  4. HP Spectre 13-4002dx Touchpad Replacement: Schritt 4, Bild 1 von 3 HP Spectre 13-4002dx Touchpad Replacement: Schritt 4, Bild 2 von 3 HP Spectre 13-4002dx Touchpad Replacement: Schritt 4, Bild 3 von 3
    • Do not disconnect the cable connector shown in the red box.
    • The speaker cable may be attached to the battery with black electrical tape. If so, remove the tape.
    • Move the cable clear of the battery.
  5. HP Spectre 13-4002dx Touchpad Replacement: Schritt 5, Bild 1 von 2 HP Spectre 13-4002dx Touchpad Replacement: Schritt 5, Bild 2 von 2
    • Do not disconnect the cable connector located in the red box.
    • Use tweezers to remove the speaker cable from the groove attached to the battery.
    • Push the cable to the side so it does not get in the way of the battery removal.
  6. HP Spectre 13-4002dx Touchpad Replacement: Schritt 6, Bild 1 von 3 HP Spectre 13-4002dx Touchpad Replacement: Schritt 6, Bild 2 von 3 HP Spectre 13-4002dx Touchpad Replacement: Schritt 6, Bild 3 von 3
    • Disconnect the battery cable connector by sliding it out of the socket.
    • Move the battery out of the way if you need more room to disconnect the power cable.
  7. HP Spectre 13-4002dx Touchpad Replacement: Schritt 7, Bild 1 von 1
    • Carefully remove the battery.
  8. HP Spectre 13-4002dx Touchpad Replacement, Touchpad: Schritt 8, Bild 1 von 3 HP Spectre 13-4002dx Touchpad Replacement, Touchpad: Schritt 8, Bild 2 von 3 HP Spectre 13-4002dx Touchpad Replacement, Touchpad: Schritt 8, Bild 3 von 3
    • The touchpad is boxed in red.
    • Remove the five 20 mm Phillips #0 screws.
  9. HP Spectre 13-4002dx Touchpad Replacement: Schritt 9, Bild 1 von 1
    • Remove the connector outlined in red.
  10. HP Spectre 13-4002dx Touchpad Replacement: Schritt 10, Bild 1 von 3 HP Spectre 13-4002dx Touchpad Replacement: Schritt 10, Bild 2 von 3 HP Spectre 13-4002dx Touchpad Replacement: Schritt 10, Bild 3 von 3
    • To release the ribbon cable, flip up the white tab on the connector 90 degrees.
    • Pull the ribbon cable out of the connector.
  11. HP Spectre 13-4002dx Touchpad Replacement: Schritt 11, Bild 1 von 1
    • Remove the touchpad.
Abschluss
Cayce Stewart
725 Reputation
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 165
