Zum Hauptinhalt wechseln
HP Spectre 13-4002dx Vent Fan Replacement
Was du brauchst
  1. HP Spectre 13-4002dx Vent Fan Replacement, Bottom Case: Schritt 1, Bild 1 von 2 HP Spectre 13-4002dx Vent Fan Replacement, Bottom Case: Schritt 1, Bild 2 von 2
    • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
  2. HP Spectre 13-4002dx Vent Fan Replacement: Schritt 2, Bild 1 von 2 HP Spectre 13-4002dx Vent Fan Replacement: Schritt 2, Bild 2 von 2
    • Pry up one corner of the bottom case with a spudger.
    • Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Remove the bottom case.
  3. HP Spectre 13-4002dx Vent Fan Replacement, Vent Fan: Schritt 3, Bild 1 von 3 HP Spectre 13-4002dx Vent Fan Replacement, Vent Fan: Schritt 3, Bild 2 von 3 HP Spectre 13-4002dx Vent Fan Replacement, Vent Fan: Schritt 3, Bild 3 von 3
    • Remove the strip of black electrical tape.
    • Pull the tape away from the vent fan.
    • Pull gently, as the tape is easy to rip.
  4. HP Spectre 13-4002dx Vent Fan Replacement: Schritt 4, Bild 1 von 2 HP Spectre 13-4002dx Vent Fan Replacement: Schritt 4, Bild 2 von 2
    • Using a Phillips #0 screwdriver, remove the two 40 mm screws securing the fan assembly to the motherboard.
  5. HP Spectre 13-4002dx Vent Fan Replacement: Schritt 5, Bild 1 von 3 HP Spectre 13-4002dx Vent Fan Replacement: Schritt 5, Bild 2 von 3 HP Spectre 13-4002dx Vent Fan Replacement: Schritt 5, Bild 3 von 3
    • Using tweezers, disconnect the wire connection between the laptop and the vent fan.
  6. HP Spectre 13-4002dx Vent Fan Replacement: Schritt 6, Bild 1 von 1
    • Remove the vent fan.
Abschluss
Cayce Stewart
725 Reputation
6 Anleitungen geschrieben
Ein Kommentar
Any idea what model# the fan is?
ayekay - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 281
