Einleitung
This guide will instruct you on how to remove and replace the battery. If the battery doesn’t hold a charge a replacement may be necessary.
Was du brauchst
Turn off and unplug the laptop.
Flip the laptop so that the backplate is exposed.
Lift the battery off of the alignment pins on the top cover and remove it from the device.
Fast fertig!
Abschluss
