Zum Hauptinhalt wechseln
HP Spectre x2 12-a002dx Battery Replacement
Was du brauchst
  1. HP Spectre x2 12-a002dx Battery Replacement, Screen: Schritt 1, Bild 1 von 1
    • Make sure the device is powered off and the kick stand is retracted.
    • The HP Spectre should be placed on a flat surface with the keyboard detached.
  2. HP Spectre x2 12-a002dx Battery Replacement: Schritt 2, Bild 1 von 3 HP Spectre x2 12-a002dx Battery Replacement: Schritt 2, Bild 2 von 3 HP Spectre x2 12-a002dx Battery Replacement: Schritt 2, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • To remove the screen, there is an entire system of clips which need to be undone as well as 4 Phillips M1.5x2.7 screws.
    • The screws should be removed using a Phillips #000 screwdriver. There is a sticker where the laptop attaches to the keyboard.
    • Heat the sticker (if needed) and use fine point tweezers to grip the sticker and remove it.
  3. HP Spectre x2 12-a002dx Battery Replacement: Schritt 3, Bild 1 von 3 HP Spectre x2 12-a002dx Battery Replacement: Schritt 3, Bild 2 von 3 HP Spectre x2 12-a002dx Battery Replacement: Schritt 3, Bild 3 von 3
    • Use the plastic opening tools or insert a spudger to begin unclipping the system.
    • Pry the screen off once all the clips have been unclipped.
    • The screen may shatter if not already shattered (beware of flying glass).
    • This screen will break. There is double tape underneath the frame, which is not listed in here.
  4. HP Spectre x2 12-a002dx Battery Replacement: Schritt 5, Bild 1 von 3 HP Spectre x2 12-a002dx Battery Replacement: Schritt 5, Bild 2 von 3 HP Spectre x2 12-a002dx Battery Replacement: Schritt 5, Bild 3 von 3
    • Remove the connecting cable of the screen and battery. Use a spudger to reveal the adhesive strip and carefully peel it off.
    • Insert a spudger to the other end and release the ZIF connectors. Detach the cable.
    • While a metal spudger is pictured, use a black nylon spudger instead because it is ESD safe.
  5. HP Spectre x2 12-a002dx Battery Replacement, Battery: Schritt 6, Bild 1 von 1
    • The battery for this device is under the screen and takes up most of the space.
  6. HP Spectre x2 12-a002dx Battery Replacement: Schritt 7, Bild 1 von 3 HP Spectre x2 12-a002dx Battery Replacement: Schritt 7, Bild 2 von 3 HP Spectre x2 12-a002dx Battery Replacement: Schritt 7, Bild 3 von 3
    • Pull the wire gently towards the connector.
    • Then, disconnect the wire and remove it from the device.
  7. HP Spectre x2 12-a002dx Battery Replacement: Schritt 8, Bild 1 von 2 HP Spectre x2 12-a002dx Battery Replacement: Schritt 8, Bild 2 von 2
    • Remove the six Phillips M2.0×3.5 screws connecting the battery to the device using the JIS 00 screwdriver.
    • Make sure to keep the screws in a safe place. You will need to use them to secure the replacement battery back in place.
  8. HP Spectre x2 12-a002dx Battery Replacement: Schritt 9, Bild 1 von 2 HP Spectre x2 12-a002dx Battery Replacement: Schritt 9, Bild 2 von 2
    • Use the tip of a spudger to push the battery connector out of its socket.
    • It helps to "walk" the connector out by pressing first on one side, then the other.
  9. HP Spectre x2 12-a002dx Battery Replacement: Schritt 10, Bild 1 von 2 HP Spectre x2 12-a002dx Battery Replacement: Schritt 10, Bild 2 von 2
    • Lift up the side of the battery that isn't glued down with adhesive
    • Use the spatula to gently scrape away the adhesive while applying a gentle upward pressure to help break the adhesive bonds.
    • A metal spudger was used again as pictured, but the black nylon spudger would be more appropriate to use.
  10. HP Spectre x2 12-a002dx Battery Replacement: Schritt 11, Bild 1 von 1
    • Finally remove the old battery.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team S10-G6, Thompson Fall 2017 Mitglied von USF Tampa, Team S10-G6, Thompson Fall 2017
USFT-THOMPSON-F17S10G6
4 Mitglieder
7 Anleitungen geschrieben
17 Kommentare zur Anleitung
Awesome, thanks a lot! My old Spectre’s battery now only supports less than 2 hours, wish I could replace it with a new one.
Claud Monet - Antwort
Clear - Complete - Accurate instructions led me through the successful replacement. glad I found this. Good Job.
Mayne Mihacsi - Antwort
Did the screen crack for you
Tiffany -
Where can the replacement battery be purchased?
Jay Mac - Antwort
Did the screen crack for anyone?
Tiffany - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 76
Insgesamt: 12,965
