Einleitung
Does your HP Spectre x360 13-4103dx laptop get hot for long periods of time, then suddenly shut down on its own or you hear the fan working constantly on a full speed? You most likely are experiencing troubles with its cooling fan which requires replacement. A working cooling fan permits air to flow in your laptop to keep its internal components cool and from overheating.
Was du brauchst
Disconnect the group of fan wires from the motherboard.
Lift the fan up to remove it from the laptop.
