Zum Hauptinhalt wechseln
HP Spectre x360 13-4103dx Touch Pad Replacement
Was du brauchst
  1. HP Spectre x360 13-4103dx Touch Pad Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Turn off your laptop before you start.
    • Flip your laptop so the bottom is facing upwards.
  2. HP Spectre x360 13-4103dx Touch Pad Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips #0 to remove the screws that hold the back panel down.
  3. HP Spectre x360 13-4103dx Touch Pad Replacement: Schritt 3, Bild 1 von 1
    • Use an opening tool to remove the back panel.
    • Be careful when applying force to the panel so the components and the panel are not damaged.
    • Try to start at a corner or a place with the most room to slide under the panel.
  4. HP Spectre x360 13-4103dx Touch Pad Replacement, Battery: Schritt 4, Bild 1 von 2 HP Spectre x360 13-4103dx Touch Pad Replacement, Battery: Schritt 4, Bild 2 von 2
    • Remove the four screws from the battery using a Phillips #0 screwdriver.
  5. HP Spectre x360 13-4103dx Touch Pad Replacement: Schritt 5, Bild 1 von 1
    • Remove the battery from the computer.
  6. HP Spectre x360 13-4103dx Touch Pad Replacement, Touch Pad: Schritt 6, Bild 1 von 3 HP Spectre x360 13-4103dx Touch Pad Replacement, Touch Pad: Schritt 6, Bild 2 von 3 HP Spectre x360 13-4103dx Touch Pad Replacement, Touch Pad: Schritt 6, Bild 3 von 3
    • Remove the five screws from the trackpad using a Phillips #0 screwdriver.
  7. HP Spectre x360 13-4103dx Touch Pad Replacement: Schritt 7, Bild 1 von 1
    • Gently unplug the ribbon cable that is attached to the computer.
  8. HP Spectre x360 13-4103dx Touch Pad Replacement: Schritt 8, Bild 1 von 1
    • Remove the touchpad from the computer.
Abschluss
UMass Dartmouth, Team 3-6, Sinclaire Fall 2021 Mitglied von UMass Dartmouth, Team 3-6, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G6
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 600
