Zum Hauptinhalt wechseln
HP Spectre x360 13-4103dx Wi-Fi Card Replacement
Was du brauchst
  1. HP Spectre x360 13-4103dx Wi-Fi Card Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Turn off your laptop before you start.
    • Flip your laptop so the bottom is facing upwards.
  2. HP Spectre x360 13-4103dx Wi-Fi Card Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips #0 to remove the screws that hold the back panel down.
  3. HP Spectre x360 13-4103dx Wi-Fi Card Replacement: Schritt 3, Bild 1 von 1
    • Use an opening tool to remove the back panel.
    • Be careful when applying force to the panel so the components and the panel are not damaged.
    • Try to start at a corner or a place with the most room to slide under the panel.
  4. HP Spectre x360 13-4103dx Wi-Fi Card Replacement, Wi-Fi Card: Schritt 4, Bild 1 von 1
    • Remove the single screw from the Wi-Fi card using a Phillips #0 screwdriver.
  5. HP Spectre x360 13-4103dx Wi-Fi Card Replacement: Schritt 5, Bild 1 von 1
    • Pull the Wi-Fi card out of the computer.
Abschluss
UMass Dartmouth, Team 3-6, Sinclaire Fall 2021 Mitglied von UMass Dartmouth, Team 3-6, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G6
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 129
