Einleitung
If your HP Spectre x360 13-ac023dx laptop will not boot up after troubleshooting possibles errors, use this motherboard replacement guide.
Was du brauchst
Use a Torx #5 screwdriver to remove the six 3.5 mm screws holding the back cover to the laptop.
Use the Phillips #000 screwdriver to remove the four 3.5 mm screws holding the battery.
After removing the screws, detach the battery wire from the mother board with the iFixit opening tool.
Then, carefully lift the battery off with the iFixit opening tool.
Use the Phillips #000 screwdriver to remove the 3mm screws holding the fan in place.
Remove the wires connecting to the motherboard, using the iFixit opening tool.
Use the Phillips #000 screwdriver to remove the screw holding the wifi card in place.
Once the screw is removed, raise the WiFi card and slide it out from the motherboard.
Ensure that all other components which were previously removed are not longer attached.
Disconnect the wires which connect the motherboard to the rest of the components.
Use the Phillips #000 screwdriver to remove the three 3.5 mm screws which keep the motherboard in place.
