Zum Hauptinhalt wechseln
HP Spectre x360 13-ac023dx WiFi Card Replacement
Was du brauchst
  1. HP Spectre x360 13-ac023dx WiFi Card Replacement, Battery: Schritt 1, Bild 1 von 2 HP Spectre x360 13-ac023dx WiFi Card Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the laptop over so the model sticker faces the ceiling.
  2. HP Spectre x360 13-ac023dx WiFi Card Replacement: Schritt 2, Bild 1 von 3 HP Spectre x360 13-ac023dx WiFi Card Replacement: Schritt 2, Bild 2 von 3 HP Spectre x360 13-ac023dx WiFi Card Replacement: Schritt 2, Bild 3 von 3
    • Use a Torx #5 screwdriver to remove the six 3.5 mm screws holding the back cover to the laptop.
  3. HP Spectre x360 13-ac023dx WiFi Card Replacement: Schritt 3, Bild 1 von 2 HP Spectre x360 13-ac023dx WiFi Card Replacement: Schritt 3, Bild 2 von 2
    • Use the Phillips #000 screwdriver to remove the four 3.5 mm screws holding the battery.
    • After removing the screws, detach the battery wire from the mother board with the iFixit opening tool.
    • Then, carefully lift the battery off with the iFixit opening tool.
  4. HP Spectre x360 13-ac023dx WiFi Card Replacement, WiFi Card: Schritt 4, Bild 1 von 1
    • Locate the WiFi card in the top left of the motherboard.
  5. HP Spectre x360 13-ac023dx WiFi Card Replacement: Schritt 5, Bild 1 von 1
    • Use the Phillips #000 screwdriver to remove the screw holding the wifi card in place.
  6. HP Spectre x360 13-ac023dx WiFi Card Replacement: Schritt 6, Bild 1 von 2 HP Spectre x360 13-ac023dx WiFi Card Replacement: Schritt 6, Bild 2 von 2
    • Once the screw is removed, hold the WiFi card by it's sides and raise it up whiling sliding it out from the slot.
  7. HP Spectre x360 13-ac023dx WiFi Card Replacement: Schritt 7, Bild 1 von 1
    • After removing the Wifi card, place the card within a static dissipative bag.
  8. HP Spectre x360 13-ac023dx WiFi Card Replacement: Schritt 8, Bild 1 von 1
    • Hold the replacement Wifi card by the edges and remove it out of the static-dissipative bag.
  9. HP Spectre x360 13-ac023dx WiFi Card Replacement: Schritt 9, Bild 1 von 1
    • Align the notches on the Wifi card with the keys on the Wifi card slot.
    • Hold the card by the edges and slide the Wifi card into the Wifi Card slot.
  10. HP Spectre x360 13-ac023dx WiFi Card Replacement: Schritt 10, Bild 1 von 1
    • Use the Phillips #000 screwdriver to attach the screw holding the Wifi card in place.
Abschluss
Jonathan
498 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S1-G6, Botvin Fall 2019 Mitglied von UMass Dartmouth, Team S1-G6, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G6
3 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 1,988
