Einleitung
If the speakers on your HP Specter laptop are not working use this step by step guide to show you how to remove and replace them.
Was du brauchst
Use two opening tools, one on either side of the battery plug, to slowly pull the plug straight out of its port.
Use a Phillips #00 screwdriver to remove the six 2.5 mm screws securing the battery.
Carefully lift the edge of the battery with an opening tool.
Lift the battery up and out.
Use a small pry tool to lift up and disconnect the speaker cable from the motherboard.
