Zum Hauptinhalt wechseln
HP Spectre x360 13t-4000 Bottom Cover Replacement
Was du brauchst
  1. HP Spectre x360 13t-4000 Bottom Cover Replacement, Bottom Cover: Schritt 1, Bild 1 von 2 HP Spectre x360 13t-4000 Bottom Cover Replacement, Bottom Cover: Schritt 1, Bild 2 von 2
    • Turn off and unplug the laptop.
    • Flip over the laptop so that the bottom backplate is exposed.
  2. HP Spectre x360 13t-4000 Bottom Cover Replacement: Schritt 2, Bild 1 von 2 HP Spectre x360 13t-4000 Bottom Cover Replacement: Schritt 2, Bild 2 von 2
    • Use a T5 screwdriver to remove the six 3 mm screws that secure the backplate.
    • Use the same screwdriver to remove the two 7 mm screws.
  3. HP Spectre x360 13t-4000 Bottom Cover Replacement: Schritt 3, Bild 1 von 3 HP Spectre x360 13t-4000 Bottom Cover Replacement: Schritt 3, Bild 2 von 3 HP Spectre x360 13t-4000 Bottom Cover Replacement: Schritt 3, Bild 3 von 3
    • Insert an opening tool under the bottom cover at the screen hinges, and gently pry the cover free.
    • Carefully work your way around the cover's edges to pop it off completely.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team S2-G4, Simcock Spring 2019 Mitglied von UMass Dartmouth, Team S2-G4, Simcock Spring 2019
UMASSD-SIMCOCK-S19S2G4
3 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Any idea for previous model like acxxxx? The 5mm screw aren't visible, bit it's like if they are there. The corners won't come out. Is the screws hidden deep under the rubber pad? Removed the rubber, do we need to somehow remove the plastic part on which the rubber pad are glued? If so how? They seems to be glued on
Ben - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 16
Insgesamt: 1,112
