Einleitung
If the back panel of the device is damaged or worn, use this guide to access, remove, and replace your back panel.
Was du brauchst
Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
Remove the four 4-mm Phillips #0 screws.
Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
