Zum Hauptinhalt wechseln
HP Split x2 13-g210dx Docking Port Replacement
Was du brauchst
  1. HP Split x2 13-g210dx Docking Port Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
    • Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
    • Remove the four 4-mm Phillips #0 screws.
    • Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
    • You will hear popping noises as the clips separate from each other.
  2. HP Split x2 13-g210dx Docking Port Replacement, Battery: Schritt 2, Bild 1 von 1
    • Remove the three 6-mm Phillips #0 screws.
  3. HP Split x2 13-g210dx Docking Port Replacement: Schritt 3, Bild 1 von 2 HP Split x2 13-g210dx Docking Port Replacement: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the white connector clip from the connector port using a sturdy tweezers.
  4. HP Split x2 13-g210dx Docking Port Replacement: Schritt 4, Bild 1 von 2 HP Split x2 13-g210dx Docking Port Replacement: Schritt 4, Bild 2 von 2
    • Lift the battery away from the device.
  5. HP Split x2 13-g210dx Docking Port Replacement, Docking Port: Schritt 5, Bild 1 von 1
    • Remove the two 4-mm Phillips #0 screws.
  6. HP Split x2 13-g210dx Docking Port Replacement: Schritt 6, Bild 1 von 2 HP Split x2 13-g210dx Docking Port Replacement: Schritt 6, Bild 2 von 2
    Kaufen
    • Remove the clips from the docking port board with a sturdy pair of tweezers.
  7. HP Split x2 13-g210dx Docking Port Replacement: Schritt 7, Bild 1 von 2 HP Split x2 13-g210dx Docking Port Replacement: Schritt 7, Bild 2 von 2
    • Remove the two ribbons labeled "Dock" at the top of the docking port board using tweezers or a sturdy plastic opening tool.
  8. HP Split x2 13-g210dx Docking Port Replacement: Schritt 8, Bild 1 von 1
    • Lift the docking port away from the device.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 833
