Einleitung
If the keyboard does not function when connected to the laptop display, or is operating in a faulty manner, then the docking port is defective. Use this guide to access, remove, and replace your docking port.
Was du brauchst
Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
Remove the four 4-mm Phillips #0 screws.
Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
Remove the three 6-mm Phillips #0 screws.
Remove the two ribbons labeled "Dock" at the top of the docking port board using tweezers or a sturdy plastic opening tool.
