Zum Hauptinhalt wechseln
HP Split x2 13-g210dx Speakers Replacement
Was du brauchst
  1. HP Split x2 13-g210dx Speakers Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
    • Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
    • Remove the four 4-mm Phillips #0 screws.
    • Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
    • You will hear popping noises as the clips separate from each other.
  2. HP Split x2 13-g210dx Speakers Replacement, Battery: Schritt 2, Bild 1 von 1
    • Remove the three 6-mm Phillips #0 screws.
  3. HP Split x2 13-g210dx Speakers Replacement: Schritt 3, Bild 1 von 2 HP Split x2 13-g210dx Speakers Replacement: Schritt 3, Bild 2 von 2
    • Remove the white connector clip from the connector port using a sturdy tweezers.
  4. HP Split x2 13-g210dx Speakers Replacement: Schritt 4, Bild 1 von 2 HP Split x2 13-g210dx Speakers Replacement: Schritt 4, Bild 2 von 2
    • Lift the battery away from the device.
  5. HP Split x2 13-g210dx Speakers Replacement, Docking Port: Schritt 5, Bild 1 von 1
    • Remove the two 4-mm Phillips #0 screws.
  6. HP Split x2 13-g210dx Speakers Replacement: Schritt 6, Bild 1 von 2 HP Split x2 13-g210dx Speakers Replacement: Schritt 6, Bild 2 von 2
    • Remove the clips from the docking port board with a sturdy pair of tweezers.
  7. HP Split x2 13-g210dx Speakers Replacement: Schritt 7, Bild 1 von 2 HP Split x2 13-g210dx Speakers Replacement: Schritt 7, Bild 2 von 2
    • Remove the two ribbons labeled "Dock" at the top of the docking port board using tweezers or a sturdy plastic opening tool.
  8. HP Split x2 13-g210dx Speakers Replacement: Schritt 8, Bild 1 von 1
    • Lift the docking port away from the device.
  9. HP Split x2 13-g210dx Speakers Replacement, SD Port: Schritt 9, Bild 1 von 1
  10. HP Split x2 13-g210dx Speakers Replacement: Schritt 10, Bild 1 von 2 HP Split x2 13-g210dx Speakers Replacement: Schritt 10, Bild 2 von 2
    • Remove the yellow ribbon labeled "SD" in the left corner of the SD port board using tweezers or a sturdy plastic opening tool.
  11. HP Split x2 13-g210dx Speakers Replacement: Schritt 11, Bild 1 von 1
    • Lift the SD port away from the device.
  12. HP Split x2 13-g210dx Speakers Replacement, Audio Port: Schritt 12, Bild 1 von 1
  13. HP Split x2 13-g210dx Speakers Replacement: Schritt 13, Bild 1 von 3 HP Split x2 13-g210dx Speakers Replacement: Schritt 13, Bild 2 von 3 HP Split x2 13-g210dx Speakers Replacement: Schritt 13, Bild 3 von 3
    • Remove the two purple ribbons labeled "Audio" at the top of the audio port board using tweezers or a sturdy plastic opening tool.
  14. HP Split x2 13-g210dx Speakers Replacement: Schritt 14, Bild 1 von 2 HP Split x2 13-g210dx Speakers Replacement: Schritt 14, Bild 2 von 2
    • Remove the white clip at the top right corner of the audio port board using tweezers.
  15. HP Split x2 13-g210dx Speakers Replacement: Schritt 15, Bild 1 von 1
    • Lift the Audio port away from the device.
  16. HP Split x2 13-g210dx Speakers Replacement, Speakers: Schritt 16, Bild 1 von 2 HP Split x2 13-g210dx Speakers Replacement, Speakers: Schritt 16, Bild 2 von 2
    • Remove the 4-mm Phillips #0 screw.
    • Lift the left speaker away from the device.
  17. HP Split x2 13-g210dx Speakers Replacement: Schritt 17, Bild 1 von 2 HP Split x2 13-g210dx Speakers Replacement: Schritt 17, Bild 2 von 2
    • Remove the 4-mm Phillips #0 screw from the same location as found on the left speaker.
    • Lift the right speaker away from the device.
  18. HP Split x2 13-g210dx Speakers Replacement: Schritt 18, Bild 1 von 3 HP Split x2 13-g210dx Speakers Replacement: Schritt 18, Bild 2 von 3 HP Split x2 13-g210dx Speakers Replacement: Schritt 18, Bild 3 von 3
    • Carefully remove the bonded white and black speaker wires running along the bottom of the control board from the fastening clips.
    • Lift the speaker assembly away from the device.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 9
Insgesamt: 269
