Einleitung
This guide will help to assist in the removal of the HP Sprocket 2-in-1 battery. Batteries can become damage when exposed to extreme temperatures, be sure to complete this tutorial in a well lit, room temperature environment.
Was du brauchst
Using the Jimmy, slowly pry open the outer edge of the remaining white plastic on the back.
Remove the plastic from the device once it lifts out freely.
Remove two 2.5mm JIS #00 located on the small circuit board in view.
Use the Jimmy to remove the board after the screws have been removed.
Remove two 2.5mm JIS #00 screws from the translucent plastic bracket.
Remove the translucent plastic bracket by hand.
Use the iFixit opening tool to slowly work between the white and beige casing around the device.
Flip the device over and seperate the white casing from the rest of the device.
Use a JIS #00 screwdriver to remove a single black screw near the viewfinder.
Remove a single silver 2.5mm JIS #00 screw near the USB port of the device.
Carefully remove the metal bracket.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
7 Kommentare
Awesome guide. Just turned on my sprocket after 9 months and the battery is definitely dead. I will definitely be using your guide in the days to come. But where did you get the replacement battery from?
Cheers,
Did you ever figure out where to buy a battery?
The original post is old asking where to find a replacement battery, but hopefully this post will help those that find this installation video. Amazon has the batteries for about $26.00. Here’s a link to help out.
Replacement Battery for HP Sprocket 200,PN:1AS84-60006,Photo Printer Battery https://a.co/d/2gML4tv
Hola, donde puedo comprar la bateria de HP Sprocket 100? Li-ion Polymer Battery Model: P0562-LF. Desde ya muchas gracias.
