Einleitung
This guide will showcase the steps necessary to remove the HP Sprocket 2-in-1 camera assembly in case of a fault. Be careful when doing so in a dusty environment as dust can impact image quality after the reinstalling a new lens. Furthermore, be sure to complete this guide in a well-lit environment to avoid potential issues that can arise when handling very small screws.
Was du brauchst
Using the Jimmy, slowly pry open the outer edge of the remaining white plastic on the back.
Remove the plastic from the device once it lifts out freely.
Remove two 2.5mm JIS #00 located on the small circuit board in view.
Use the Jimmy to remove the board after the screws have been removed.
Remove two 2.5mm JIS #00 screws from the translucent plastic bracket.
Remove the translucent plastic bracket by hand.
Use the iFixit opening tool to slowly work between the white and beige casing around the device.
Flip the device over and seperate the white casing from the rest of the device.
Use the Japanese Industrial Standard J00 screwdriver to remove five 2.5mm screws.
Remove the metal plate from the casing.
