Zum Hauptinhalt wechseln
HP Sprocket 2-in-1 Outer Casing Replacement
Was du brauchst
  1. HP Sprocket 2-in-1 Outer Casing Replacement, Outer Casing: Schritt 1, Bild 1 von 2 HP Sprocket 2-in-1 Outer Casing Replacement, Outer Casing: Schritt 1, Bild 2 von 2
    • Remove the back cover and any printer paper inside the device.
  2. HP Sprocket 2-in-1 Outer Casing Replacement: Schritt 2, Bild 1 von 2 HP Sprocket 2-in-1 Outer Casing Replacement: Schritt 2, Bild 2 von 2
    • Using the Jimmy, slowly pry open the outer edge of the remaining white plastic on the back.
    • Remove the plastic from the device once it lifts out freely.
  3. HP Sprocket 2-in-1 Outer Casing Replacement: Schritt 3, Bild 1 von 3 HP Sprocket 2-in-1 Outer Casing Replacement: Schritt 3, Bild 2 von 3 HP Sprocket 2-in-1 Outer Casing Replacement: Schritt 3, Bild 3 von 3
    • Remove two 2.5mm JIS #00 located on the small circuit board in view.
    • Use the Jimmy to remove the board after the screws have been removed.
    • Be careful not to crease or damage the ribbon cable.
  4. HP Sprocket 2-in-1 Outer Casing Replacement: Schritt 4, Bild 1 von 3 HP Sprocket 2-in-1 Outer Casing Replacement: Schritt 4, Bild 2 von 3 HP Sprocket 2-in-1 Outer Casing Replacement: Schritt 4, Bild 3 von 3
    • Remove two 2.5mm JIS #00 screws from the translucent plastic bracket.
    • One will be located beneath the ribbon cable.
    • Remove the translucent plastic bracket by hand.
  5. HP Sprocket 2-in-1 Outer Casing Replacement: Schritt 5, Bild 1 von 2 HP Sprocket 2-in-1 Outer Casing Replacement: Schritt 5, Bild 2 von 2
    • Remove four 2.5mm JIS #00 screws from the beige casing.
  6. HP Sprocket 2-in-1 Outer Casing Replacement: Schritt 6, Bild 1 von 3 HP Sprocket 2-in-1 Outer Casing Replacement: Schritt 6, Bild 2 von 3 HP Sprocket 2-in-1 Outer Casing Replacement: Schritt 6, Bild 3 von 3
    • Use the iFixit opening tool to slowly work between the white and beige casing around the device.
    • Flip the device over and seperate the white casing from the rest of the device.
    • Be careful not to break the plastic while removing the case.
    • Gently remove the white casing as there is a ribbon cable connecting the two pieces.
  7. HP Sprocket 2-in-1 Outer Casing Replacement: Schritt 7, Bild 1 von 1
    • Carefully remove the ribbon cable that connects the flash to the outer casing.
Abschluss
University of Michigan, Team S1-G4, Li Winter 2019 Mitglied von University of Michigan, Team S1-G4, Li Winter 2019
UMIC-LI-W19S1G4
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 335
