Einleitung
This guide is necessary for all replacement guides for the HP Sprocket 2-in-1. All the images and directions use the iFixit Pro Tool Tech Kit. It is not necessary to use the kit but it is recommended. Be sure to prepare all tools and the device in a well-lit environment.
Was du brauchst
Using the Jimmy, slowly pry open the outer edge of the remaining white plastic on the back.
Remove the plastic from the device once it lifts out freely.
Remove two 2.5mm JIS #00 located on the small circuit board in view.
Use the Jimmy to remove the board after the screws have been removed.
Remove two 2.5mm JIS #00 screws from the translucent plastic bracket.
Remove the translucent plastic bracket by hand.
Use the iFixit opening tool to slowly work between the white and beige casing around the device.
Flip the device over and seperate the white casing from the rest of the device.
