Einleitung
The USB port on the HP Sprocket 2-in-1 is a micro-USB port. The removal of said port will involve navigating and detaching numerous small and delicate ribbon cables. Be sure to avoid aggressive movements while completing the guide to avoid taring connections to other vital components.
Was du brauchst
Using the Jimmy, slowly pry open the outer edge of the remaining white plastic on the back.
Remove the plastic from the device once it lifts out freely.
Remove two 2.5mm JIS #00 located on the small circuit board in view.
Use the Jimmy to remove the board after the screws have been removed.
Remove two 2.5mm JIS #00 screws from the translucent plastic bracket.
Remove the translucent plastic bracket by hand.
Use the iFixit opening tool to slowly work between the white and beige casing around the device.
Flip the device over and seperate the white casing from the rest of the device.
Use a JIS #00 screwdriver to remove a single black screw near the viewfinder.
Remove a single silver 2.5mm JIS #00 screw near the USB port of the device.
Carefully remove the metal bracket.
Using the metal tweezers, remove the ribbon from the motherboard.
Remove two 2.5mm Japanese Industrial Standard (J00) screws on each side of the USB port.
Remove the SD Port with metal tweezers.
You can now replace the SD port with a new one.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
