Was du brauchst
Use a prying tool to pry the 2 rubber feet off closest to the hinge of the device
Repeat this process for the other side of the device
The bottom rubber feet do not have hidden screws underneath them, and as such, they are unnecessary to remove
Use your finger to pry the outer blue shell over the keyboard
Continue this process around the edges of the device
You may have to use a prying tool to pry the harder edges such as around the I/O ports
Do not lift the keyboard once all the clips are undone, as there are still various cables connected
Disconnect the power button connector by peeling back the protective tape, using your fingernail to flip the white retaining clip back, and pulling the ribbon cable out
Disconnect the touchpad connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
Disconnect the keyboard connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
Your keyboard assembly is now safe to remove
Remove the power button connector from the power button by flipping the white tab up and pulling the ribbon cable out
Eine weitere Person hat diese Anleitung absolviert.
