Was du brauchst
Pry off the two elliptical rubber inserts (one in each corner).
Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
Using an iFixit opening tool, pry open the case to separate the keyboard from the main body.
Carefully lift the keyboard and locate the three ribbon cables connecting the main body of the laptop to the keyboard.
Using your fingernail, lift the flaps on the ZIF connectors that are securing the three ribbon cables.
Carefully disconnect the three ribbon cables.
