Zum Hauptinhalt wechseln
HP Stream 11-d020nr Keyboard Replacement
Was du brauchst
  1. HP Stream 11-d020nr Keyboard Replacement, Lower Case: Schritt 1, Bild 1 von 3 HP Stream 11-d020nr Keyboard Replacement, Lower Case: Schritt 1, Bild 2 von 3 HP Stream 11-d020nr Keyboard Replacement, Lower Case: Schritt 1, Bild 3 von 3
    • Before disassembly, unplug and power off the Stream 11.
    • Pry off the two elliptical rubber inserts (one in each corner).
    • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
  2. HP Stream 11-d020nr Keyboard Replacement: Schritt 2, Bild 1 von 2 HP Stream 11-d020nr Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Remove the eleven 5.6 mm Phillips #00 screws.
  3. HP Stream 11-d020nr Keyboard Replacement: Schritt 3, Bild 1 von 3 HP Stream 11-d020nr Keyboard Replacement: Schritt 3, Bild 2 von 3 HP Stream 11-d020nr Keyboard Replacement: Schritt 3, Bild 3 von 3
    • Turn the computer upright and lift the screen.
    • Carefully use a spudger to pry the plastic keyboard cover from the base.
    • When using the metal spudger, be careful not to press into the components underneath the keyboard cover. If possible, use a standard spudger or plastic opening tool to remove the keyboard cover.
    • Work the spudger around the cover to release the clips attaching the cover to the base.
    • Be patient when removing the cover, as there are many clips and it may take some time.
  4. HP Stream 11-d020nr Keyboard Replacement: Schritt 4, Bild 1 von 3 HP Stream 11-d020nr Keyboard Replacement: Schritt 4, Bild 2 von 3 HP Stream 11-d020nr Keyboard Replacement: Schritt 4, Bild 3 von 3
    • Disconnect the cable connecting the ClickPad to the base.
    • Remove the plastic keyboard cover.
    • The cover is attached to the ClickPad by a cable. Be careful not to lift the cover too far so you do not damage this cable.
  5. HP Stream 11-d020nr Keyboard Replacement, Keyboard: Schritt 5, Bild 1 von 2 HP Stream 11-d020nr Keyboard Replacement, Keyboard: Schritt 5, Bild 2 von 2
    • Tilt the top of the keyboard plate up until you separate it from the base.
    • Tilt the keyboard toward you slowly but do not remove it, it is still connected with ribbon cables.
  6. HP Stream 11-d020nr Keyboard Replacement: Schritt 6, Bild 1 von 3 HP Stream 11-d020nr Keyboard Replacement: Schritt 6, Bild 2 von 3 HP Stream 11-d020nr Keyboard Replacement: Schritt 6, Bild 3 von 3
    • Lift up the retaining flaps on the ZIF connectors securing the two keyboard ribbon cables.
    • After disengaging the connectors, gently unplug both ribbon cables.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Spenser Mason
1.763 Reputation
6 Anleitungen geschrieben
USF Tampa, Team 3-5, Wollert Spring 2016 Mitglied von USF Tampa, Team 3-5, Wollert Spring 2016
USFT-WOLLERT-S16S3G5
5 Mitglieder
19 Anleitungen geschrieben
Ein Kommentar
This repair is disingenuous and misleading. The computer used in these photos was previously worked on. All of the pictures and instructions in Step 4 and Step 5 prove this. In those pictures the keyboard is a physically separate piece from the plastic top case. This is NOT how this computer is assembled. In fact the keyboard is plastic welded to the top case. The top case does not separate from the keyboard as seen in Step 4 and Step 5. You need to fully remove the top case (which contains the keyboard and trackpad), disconnect three cables, remove a large copper support and a small black plastic support, peel off a big sheet of plastic and graphite insulation tape, then cut about 25 plastic welds that hold the keyboard support to the top case. Only then you can separate the keyboard from the top case.
Steve - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 22
Insgesamt: 9,430
