Zum Hauptinhalt wechseln
Einleitung
Use this guide to remove the lower case of the HP Stream 11-d020nr. This should take you about 5-10 minutes. Use caution when taking the cover off of the laptop. The process requires a significant amount of force, and it can be easy to damage the internal components.
Ersatzteile
Keine Ersatzteile angegeben.
  1. HP Stream 11-d020nr Lower Case Replacement, Lower Case: Schritt 1, Bild 1 von 3 HP Stream 11-d020nr Lower Case Replacement, Lower Case: Schritt 1, Bild 2 von 3 HP Stream 11-d020nr Lower Case Replacement, Lower Case: Schritt 1, Bild 3 von 3
    • Before disassembly, unplug and power off the Stream 11.
    • Pry off the two elliptical rubber inserts (one in each corner).
    • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
  2. HP Stream 11-d020nr Lower Case Replacement: Schritt 2, Bild 1 von 2 HP Stream 11-d020nr Lower Case Replacement: Schritt 2, Bild 2 von 2
    • Remove the eleven 5.6 mm Phillips #00 screws.
  3. HP Stream 11-d020nr Lower Case Replacement: Schritt 3, Bild 1 von 3 HP Stream 11-d020nr Lower Case Replacement: Schritt 3, Bild 2 von 3 HP Stream 11-d020nr Lower Case Replacement: Schritt 3, Bild 3 von 3
    • Turn the computer upright and lift the screen.
    • Carefully use a spudger to pry the plastic keyboard cover from the base.
    • When using the metal spudger, be careful not to press into the components underneath the keyboard cover. If possible, use a standard spudger or plastic opening tool to remove the keyboard cover.
    • Work the spudger around the cover to release the clips attaching the cover to the base.
    • Be patient when removing the cover, as there are many clips and it may take some time.
  4. HP Stream 11-d020nr Lower Case Replacement: Schritt 4, Bild 1 von 3 HP Stream 11-d020nr Lower Case Replacement: Schritt 4, Bild 2 von 3 HP Stream 11-d020nr Lower Case Replacement: Schritt 4, Bild 3 von 3
    • Disconnect the cable connecting the ClickPad to the base.
    • Remove the plastic keyboard cover.
    • The cover is attached to the ClickPad by a cable. Be careful not to lift the cover too far so you do not damage this cable.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team 3-5, Wollert Spring 2016 Mitglied von USF Tampa, Team 3-5, Wollert Spring 2016
USFT-WOLLERT-S16S3G5
5 Mitglieder
19 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 3
Letzten 30 Tage: 26
Insgesamt: 1,357
