Zum Hauptinhalt wechseln
Einleitung
Use this guide to remove the lower case of the HP Stream 11-d020nr. This should take you about 5-10 minutes. Use caution when taking the cover off of the laptop. The process requires a significant amount of force, and it can be easy to damage the internal components.
  1. Before disassembly, unplug and power off the Stream 11. Pry off the two elliptical rubber inserts (one in each corner). Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
    • Before disassembly, unplug and power off the Stream 11.
    • Pry off the two elliptical rubber inserts (one in each corner).
    • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
  2. Remove the eleven 5.6 mm Phillips #00 screws. Remove the eleven 5.6 mm Phillips #00 screws.
    • Remove the eleven 5.6 mm Phillips #00 screws.
  3. Turn the computer upright and lift the screen. Carefully use a spudger to pry the plastic keyboard cover from the base. When using the metal spudger, be careful not to press into the components underneath the keyboard cover. If possible, use a standard spudger or plastic opening tool to remove the keyboard cover.
    • Turn the computer upright and lift the screen.
    • Carefully use a spudger to pry the plastic keyboard cover from the base.
    • When using the metal spudger, be careful not to press into the components underneath the keyboard cover. If possible, use a standard spudger or plastic opening tool to remove the keyboard cover.
    • Work the spudger around the cover to release the clips attaching the cover to the base.
    • Be patient when removing the cover, as there are many clips and it may take some time.
  4. Disconnect the cable connecting the ClickPad to the base. Remove the plastic keyboard cover. The cover is attached to the ClickPad by a cable. Be careful not to lift the cover too far so you do not damage this cable.
    • Disconnect the cable connecting the ClickPad to the base.
    • Remove the plastic keyboard cover.
    • The cover is attached to the ClickPad by a cable. Be careful not to lift the cover too far so you do not damage this cable.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
USF Tampa, Team 3-5, Wollert Spring 2016 Mitglied von USF Tampa, Team 3-5, Wollert Spring 2016
USFT-WOLLERT-S16S3G5
5 Mitglieder
19 Anleitungen geschrieben
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 14
Insgesamt: 1,188
