Einleitung
Sometimes the ClickPad of the HP Stream 11-d020nr may stop working effectively. This could be caused by either a hardware or software issue. Either way, this replacement is pretty straightforward. To avoid potential electrical hazards, be sure that the laptop is unplugged and shut down before beginning your repair.
Was du brauchst
Pry off the two elliptical rubber inserts (one in each corner).
Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
Turn the computer upright and lift the screen.
Carefully use a spudger to pry the plastic keyboard cover from the base.
Work the spudger around the cover to release the clips attaching the cover to the base.
Disconnect the cable connecting the ClickPad to the base.
Remove the plastic keyboard cover.
On the back of the plastic keyboard cover, remove the two 2 mm Phillips #000 screws.
To reassemble your computer, follow these instructions in reverse order.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Can you give the Product number of the part?
