Einleitung
Computer not holding a charge? Tired of looking for outlets everywhere you go? Change your HP Stream battery!
Ersatzteile
Use a plastic spudger to remove two oblong screw covers on the bottom of the computer.
Use a plastic spudger to remove four rubber feet.
Remove the eleven 5 millimeter housing screws from the bottom of the computer using a #00 Phillips head screwdriver.
Turn the computer over and open it.
Use a plastic spudger to pry the keyboard bezel away from the base. Pry around the edge, being careful not to jam the spudger too far underneath the bezel (potentially damaging internal components).
Identify two ribbon connectors and the ZIF cable underneath the keyboard.
Use tweezers to disconnect both ribbon cables and the ZIF connector.
Use a Phillips #00 screwdriver to remove six 5 millimeter screws from the battery.
Use a plastic spudger to remove the two power connectors.
Lift the battery out.
