Zum Hauptinhalt wechseln
HP Stream 11-y010nr Keyboard Replacement
Was du brauchst
  1. HP Stream 11-y010nr Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 3 HP Stream 11-y010nr Keyboard Replacement, Keyboard: Schritt 1, Bild 2 von 3 HP Stream 11-y010nr Keyboard Replacement, Keyboard: Schritt 1, Bild 3 von 3
    • Gently peel back the two rubber strips that cover the screws on backside of the computer with the needle nose tweezers.
    • Ensure the laptop is turned off.
  2. HP Stream 11-y010nr Keyboard Replacement: Schritt 2, Bild 1 von 2 HP Stream 11-y010nr Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Unscrew the seven 0.4mm screws on the backside of the laptop with the Phillips #0 Screwdriver.
  3. HP Stream 11-y010nr Keyboard Replacement: Schritt 3, Bild 1 von 2 HP Stream 11-y010nr Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Take the opening picks and push them into the seam between the keyboard and the laptop casing.
    • Go all the way around the laptop.
  4. HP Stream 11-y010nr Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Once the cover is loose enough, lift the keyboard up to expose the wiring beneath.
    • Be careful not to pull too hard or fast as there are ribbon cables attached to the keyboard and trackpad.
  5. HP Stream 11-y010nr Keyboard Replacement: Schritt 5, Bild 1 von 3 HP Stream 11-y010nr Keyboard Replacement: Schritt 5, Bild 2 von 3 HP Stream 11-y010nr Keyboard Replacement: Schritt 5, Bild 3 von 3
    • Disconnect the three cables by lifting up on the locking tab of the ZIF connector and pulling the cables out with the needle nose tweezers.
    • Remove the keyboard.
Abschluss
To reassemble your device, follow these instructions.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 481
