Zum Hauptinhalt wechseln
HP Stream 11-y010nr Screen Replacement
Was du brauchst
  1. HP Stream 11-y010nr Screen Replacement, Keyboard: Schritt 1, Bild 1 von 3 HP Stream 11-y010nr Screen Replacement, Keyboard: Schritt 1, Bild 2 von 3 HP Stream 11-y010nr Screen Replacement, Keyboard: Schritt 1, Bild 3 von 3
    • Gently peel back the two rubber strips that cover the screws on backside of the computer with the needle nose tweezers.
    • Ensure the laptop is turned off.
  2. HP Stream 11-y010nr Screen Replacement: Schritt 2, Bild 1 von 2 HP Stream 11-y010nr Screen Replacement: Schritt 2, Bild 2 von 2
    • Unscrew the seven 0.4mm screws on the backside of the laptop with the Phillips #0 Screwdriver.
  3. HP Stream 11-y010nr Screen Replacement: Schritt 3, Bild 1 von 2 HP Stream 11-y010nr Screen Replacement: Schritt 3, Bild 2 von 2
    • Take the opening picks and push them into the seam between the keyboard and the laptop casing.
    • Go all the way around the laptop.
  4. HP Stream 11-y010nr Screen Replacement: Schritt 4, Bild 1 von 1
    • Once the cover is loose enough, lift the keyboard up to expose the wiring beneath.
    • Be careful not to pull too hard or fast as there are ribbon cables attached to the keyboard and trackpad.
  5. HP Stream 11-y010nr Screen Replacement: Schritt 5, Bild 1 von 3 HP Stream 11-y010nr Screen Replacement: Schritt 5, Bild 2 von 3 HP Stream 11-y010nr Screen Replacement: Schritt 5, Bild 3 von 3
    • Disconnect the three cables by lifting up on the locking tab of the ZIF connector and pulling the cables out with the needle nose tweezers.
    • Remove the keyboard.
  6. HP Stream 11-y010nr Screen Replacement, Screen: Schritt 6, Bild 1 von 3 HP Stream 11-y010nr Screen Replacement, Screen: Schritt 6, Bild 2 von 3 HP Stream 11-y010nr Screen Replacement, Screen: Schritt 6, Bild 3 von 3
    • Using your fingers or a spudger, pull the battery cable from its connector to disconnect power from the motherboard.
  7. HP Stream 11-y010nr Screen Replacement: Schritt 7, Bild 1 von 2 HP Stream 11-y010nr Screen Replacement: Schritt 7, Bild 2 von 2
    • Insert iFixit opening picks into the edges of the screen to break the seal between the screen and bezel.
  8. HP Stream 11-y010nr Screen Replacement: Schritt 8, Bild 1 von 3 HP Stream 11-y010nr Screen Replacement: Schritt 8, Bild 2 von 3 HP Stream 11-y010nr Screen Replacement: Schritt 8, Bild 3 von 3
    • Peel the hinge up by sliding iFixit opening picks left to right along the hinge.
  9. HP Stream 11-y010nr Screen Replacement: Schritt 9, Bild 1 von 3 HP Stream 11-y010nr Screen Replacement: Schritt 9, Bild 2 von 3 HP Stream 11-y010nr Screen Replacement: Schritt 9, Bild 3 von 3
    • Remove the bezel by pulling upwards on the left bottom corner.
  10. HP Stream 11-y010nr Screen Replacement: Schritt 10, Bild 1 von 2 HP Stream 11-y010nr Screen Replacement: Schritt 10, Bild 2 von 2
    • Disconnect the screen from the motherboard by pulling the display cable from its connector.
  11. HP Stream 11-y010nr Screen Replacement: Schritt 11, Bild 1 von 1
    • Unscrew the four 0.4mm screws surrounding the display using a Phillips #00 screwdriver.
  12. HP Stream 11-y010nr Screen Replacement: Schritt 12, Bild 1 von 3 HP Stream 11-y010nr Screen Replacement: Schritt 12, Bild 2 von 3 HP Stream 11-y010nr Screen Replacement: Schritt 12, Bild 3 von 3
    • Gently remove the screen from its holding and lay the screen down on the keyboard. It is still attached to the computer.
  13. HP Stream 11-y010nr Screen Replacement: Schritt 13, Bild 1 von 3 HP Stream 11-y010nr Screen Replacement: Schritt 13, Bild 2 von 3 HP Stream 11-y010nr Screen Replacement: Schritt 13, Bild 3 von 3
    • Take the tweezers and push up on the small connector to the left of the webcam.
  14. HP Stream 11-y010nr Screen Replacement: Schritt 14, Bild 1 von 2 HP Stream 11-y010nr Screen Replacement: Schritt 14, Bild 2 von 2
    • Gently pull the cord out from around the screen area.
  15. HP Stream 11-y010nr Screen Replacement: Schritt 15, Bild 1 von 2 HP Stream 11-y010nr Screen Replacement: Schritt 15, Bild 2 von 2
    • Remove the screen with the display cable attached.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 461
