Einleitung
This guide will show how to replace the display on the HP Stream 13-c010nr. If your screen is cracked or damaged, you can follow this guide to repair it.
Was du brauchst
Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
Flip the laptop over and open it up.
Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
Lift up the keyboard.
Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
Pull up the ribbon cables from their sockets.
Wedge the plastic opening tool between the frame of the screen and the casing of the laptop.
Pry upwards on the plastic opening tool to separate the bezel from the display.
Use a spudger to flip up the retaining flap on the screen ribbon cable ZIF socket.
Pull the ribbon cable out of the ZIF socket.
Remove the screen.
