Zum Hauptinhalt wechseln
Einleitung
This guide will teach you how to replace the USB Ports on the HP Stream 13-c010nr.
  1. Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
    • Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
  2. Remove the thirteen 5mm Phillips #0 screws from the bottom case. Remove the thirteen 5mm Phillips #0 screws from the bottom case.
    • Remove the thirteen 5mm Phillips #0 screws from the bottom case.
  3. Flip the laptop over and open it up. Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
    • Flip the laptop over and open it up.
    • Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
    • Lift up the keyboard.
    • Ribbon cables still connect the two pieces.
  4. Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
    • Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
    • Pull up the ribbon cables from their sockets.
  5. Use a spudger to flip up the retaining flap on the USB port ribbon cable ZIF socket. Pull the ribbon cable out of the socket.
    • Use a spudger to flip up the retaining flap on the USB port ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
  6. Remove the three 3mm Phillips #0 screws from the USB port. Pull out the USB port.
    • Remove the three 3mm Phillips #0 screws from the USB port.
    • Pull out the USB port.
  7. Remove the chip containing the two USB Ports.
    • Remove the chip containing the two USB Ports.
Abschluss
Keegan Lapham
731 Reputation
6 Anleitungen geschrieben
USF Tampa, Team S1-G3, Cagle Spring 2018 Mitglied von USF Tampa, Team S1-G3, Cagle Spring 2018
USFT-CAGLE-S18S1G3
4 Mitglieder
12 Anleitungen geschrieben
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 173
