Einleitung
The motherboard replacement guide will assist the user in removal and installation instructions for the HP Stream 13-c110nr.
Was du brauchst
Close the device.
Remove AC adapter plug from electrical outlet.
Remove AC adapter from device.
Turn the device off.
Unplug all external devices from device.
Use a pick to remove the two (2) large computer feet along the back edge of the device.
Use a pick to remove the two (2) small computer feet.
Use a pick to remove the one (1) screw cover.
Place rubber computer feet in safe place for reassembly.
In diesem Schritt verwendetes Werkzeug:Magnetic Project Mat$19.95
Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
Place the thirteen (13) screws on magnetic mat for reassembly.
Turn the device over with the front facing towards you.
Open the device as shown.
Insert the Spudger between the Top Cover and Bottom Cover to lift the front edge until it separates from the Bottom Cover.
Remove one (1) Phillips P0 PM2.0x3.0 mm screw.
Place one (1) screw on magnetic mat for reassembly.
Remove eight (8) Phillips P0 PM2.0x3.0 mm screws from Battery assembly.
Place eight (8) screws on magnetic mat for reassembly.
Use a pick to disconnect the USB/Card Reader cable from the System Board.
Remove three (3) Phillips P0 PM2.0x3.0 mm screws.
Place three (3) screws on magnetic mat for reassembly.
Remove two (2) Phillips P0 PM2.0x2.0 mm screws.
Place two (2) screws on magnetic mat for reassembly.
Remove five (5) Phillips P0 PM2.5x3.0 mm screws from System Board assembly.
Place five (5) screws on magnetic mat for reassembly.
