Zum Hauptinhalt wechseln
HP Stream 13-c110nr Speakers Replacement
Was du brauchst
  1. HP Stream 13-c110nr Speakers Replacement, Keyboard Assembly: Schritt 1, Bild 1 von 1
    • Close the device.
    • Remove AC adapter plug from electrical outlet.
    • Remove AC adapter from device.
    • Turn the device off.
    • Unplug all external devices from device.
    • If you are unsure whether the computer is off or in hibernation mode, start the computer and then shutdown the operating system.
  2. HP Stream 13-c110nr Speakers Replacement: Schritt 2, Bild 1 von 1
    • Turn the device upside down with the back facing towards you.
  3. HP Stream 13-c110nr Speakers Replacement: Schritt 3, Bild 1 von 3 HP Stream 13-c110nr Speakers Replacement: Schritt 3, Bild 2 von 3 HP Stream 13-c110nr Speakers Replacement: Schritt 3, Bild 3 von 3
    • Use a pick to remove the two (2) large computer feet along the back edge of the device.
    • Use a pick to remove the two (2) small computer feet.
    • Use a pick to remove the one (1) screw cover.
    • Place rubber computer feet in safe place for reassembly.
  4. HP Stream 13-c110nr Speakers Replacement: Schritt 4, Bild 1 von 3 HP Stream 13-c110nr Speakers Replacement: Schritt 4, Bild 2 von 3 HP Stream 13-c110nr Speakers Replacement: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Magnetic Project Mat
    $19.95
    • Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
    • Place the thirteen (13) screws on magnetic mat for reassembly.
  5. HP Stream 13-c110nr Speakers Replacement: Schritt 5, Bild 1 von 1
    • Turn the device over with the front facing towards you.
    • Open the device as shown.
  6. HP Stream 13-c110nr Speakers Replacement: Schritt 6, Bild 1 von 3 HP Stream 13-c110nr Speakers Replacement: Schritt 6, Bild 2 von 3 HP Stream 13-c110nr Speakers Replacement: Schritt 6, Bild 3 von 3
    • Insert the Spudger between the Top Cover and Bottom Cover to lift the front edge until it separates from the Bottom Cover.
    • Do not completely remove the Keyboard/Top cover from the Bottom cover yet.
  7. HP Stream 13-c110nr Speakers Replacement: Schritt 7, Bild 1 von 1
    • Disconnect the Touchpad cable.
  8. HP Stream 13-c110nr Speakers Replacement: Schritt 8, Bild 1 von 2 HP Stream 13-c110nr Speakers Replacement: Schritt 8, Bild 2 von 2
    • Disconnect the Keyboard Cable.
  9. HP Stream 13-c110nr Speakers Replacement: Schritt 9, Bild 1 von 2 HP Stream 13-c110nr Speakers Replacement: Schritt 9, Bild 2 von 2
    • Disconnect the Power connector cable.
  10. HP Stream 13-c110nr Speakers Replacement: Schritt 10, Bild 1 von 1
    • Remove the Keyboard/Top Cover from the device.
  11. HP Stream 13-c110nr Speakers Replacement, Battery Assembly: Schritt 11, Bild 1 von 2 HP Stream 13-c110nr Speakers Replacement, Battery Assembly: Schritt 11, Bild 2 von 2
    • Use a pick to detach the Battery assembly cable.
  12. HP Stream 13-c110nr Speakers Replacement: Schritt 12, Bild 1 von 2 HP Stream 13-c110nr Speakers Replacement: Schritt 12, Bild 2 von 2
    • Remove eight (8) Phillips P0 PM2.0x3.0 mm screws from Battery assembly.
    • Place eight (8) screws on magnetic mat for reassembly.
  13. HP Stream 13-c110nr Speakers Replacement: Schritt 13, Bild 1 von 1
    • Remove Battery Assembly from device.
  14. HP Stream 13-c110nr Speakers Replacement, Speakers: Schritt 14, Bild 1 von 2 HP Stream 13-c110nr Speakers Replacement, Speakers: Schritt 14, Bild 2 von 2
    • Use a pick to disconnect the Speaker Cable from the System Board.
  15. HP Stream 13-c110nr Speakers Replacement: Schritt 15, Bild 1 von 2 HP Stream 13-c110nr Speakers Replacement: Schritt 15, Bild 2 von 2
    • Remove two (2) P0 PM 2.0 x 3.0 mm screws from speaker assembly.
    • Place two (2) screws on magnetic mat for reassembly.
  16. HP Stream 13-c110nr Speakers Replacement: Schritt 16, Bild 1 von 1
    • Remove the Speakers from the device.
Abschluss
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 171
