Zum Hauptinhalt wechseln
HP Stream 8 Motherboard Replacement
Was du brauchst
  1. HP Stream 8 Motherboard Replacement, Midframe: Schritt 1, Bild 1 von 1
    • Use your nail or a spudger to pry the back cover off of the device.
  2. HP Stream 8 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Slide your finger around the rest of the back cover, lifting it completely off of the device.
  3. HP Stream 8 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Remove ten Phillips #00 screws from the inside cover.
  4. HP Stream 8 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Pry up the inside cover the same way as in the first step.
  5. HP Stream 8 Motherboard Replacement, Front-Facing Camera: Schritt 5, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Lift up on the small black tab at the connection point to unlock the flex ribbon cable using the tweezers.
  6. HP Stream 8 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Remove the front facing camera with tweezers.
  7. HP Stream 8 Motherboard Replacement, Rear-Facing Camera: Schritt 7, Bild 1 von 1
    • Carefully pry up the gray metal piece on the end of the flex ribbon cable using tweezers.
  8. HP Stream 8 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Remove the back facing camera with the tweezers.
  9. HP Stream 8 Motherboard Replacement, Motherboard: Schritt 9, Bild 1 von 1
    • Carefully remove the battery connector from the system board using the tweezers.
  10. HP Stream 8 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Lift up on the small black tab to unlock the LCD screen flex ribbon cable using the tweezers.
  11. HP Stream 8 Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Carefully remove the LCD screen flex ribbon cable from the system board using the tweezers.
  12. HP Stream 8 Motherboard Replacement: Schritt 12, Bild 1 von 1
    • Carefully remove the USB flex ribbon cable from the connection point on the system board using the tweezers.
  13. HP Stream 8 Motherboard Replacement: Schritt 13, Bild 1 von 1
    • Remove the two Phillips using the screwdriver with a PH00 Phillips head.
  14. HP Stream 8 Motherboard Replacement: Schritt 14, Bild 1 von 1
    • Remove the motherboard from the device.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 34-14, Maness Spring 2016 Mitglied von Cal Poly, Team 34-14, Maness Spring 2016
CPSU-MANESS-S16S34G14
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 29
Insgesamt: 1,331
