Zum Hauptinhalt wechseln
HP Stream TPN-Q155 Keyboard replacement
Was du brauchst
  1. HP Stream TPN-Q155 Keyboard replacement, HP Stream TPN-Q155 Keyboard replacement: Schritt 1, Bild 1 von 1
    • Unscrew all the screws on the back of the laptop and remove the cover
  2. HP Stream TPN-Q155 Keyboard replacement: Schritt 2, Bild 1 von 2 HP Stream TPN-Q155 Keyboard replacement: Schritt 2, Bild 2 von 2
    • Remove the black adhesive to expose plastic rivets.
  3. HP Stream TPN-Q155 Keyboard replacement: Schritt 3, Bild 1 von 3 HP Stream TPN-Q155 Keyboard replacement: Schritt 3, Bild 2 von 3 HP Stream TPN-Q155 Keyboard replacement: Schritt 3, Bild 3 von 3
    • Now, get a tissue and prepare for the sweat.
    • And melt any rivet from green marker to orange marker like. Try not to cut it off, or you might be in trouble to hold the metal cover
  4. HP Stream TPN-Q155 Keyboard replacement: Schritt 4, Bild 1 von 2 HP Stream TPN-Q155 Keyboard replacement: Schritt 4, Bild 2 von 2
    • Same process and keep melting the rest of the plastic rivets after the metal cover. This can easily going over 2 or 3 hours if you are not quick enough.
    • And if everything goes alright, you might eventually get the problem keyboard removed and put a new keyboard back in.
    • then, use your solder station the melt the plastic back to the keyboard.
Abschluss
Jim Yang
112 Reputation
1 Anleitung geschrieben
Jim The Computer Man Mitglied von Jim The Computer Man
Business
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 20
Insgesamt: 1,106
