Zum Hauptinhalt wechseln
HP Stream x360 11 -p015wm Back Cover Replacement
Was du brauchst
  1. HP Stream x360 11 -p015wm Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 2 HP Stream x360 11 -p015wm Back Cover Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Orient the laptop to have the back cover facing upwards.
    • Remove the four rubber pads located in each corner.
  2. HP Stream x360 11 -p015wm Back Cover Replacement: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    JIS Driver Set
    $19.99
    Kaufen
    • Tool required: JIS #1 Screwdriver
    • Using the screwdriver, remove all of the exposed screws.
  3. HP Stream x360 11 -p015wm Back Cover Replacement: Schritt 3, Bild 1 von 2 HP Stream x360 11 -p015wm Back Cover Replacement: Schritt 3, Bild 2 von 2
    iFixit Opening Tool
    $1.99
    Kaufen
    • Tool required: iFixit opening tool
    • Open the laptop and orient the keyboard facing upward.
    • Slowly wedge the opening tool into the gap between the keyboard and the back cover.
    • After loosening the back cover, close the laptop and orient the back cover facing upward. Open the cover.
  4. HP Stream x360 11 -p015wm Back Cover Replacement: Schritt 4, Bild 1 von 2 HP Stream x360 11 -p015wm Back Cover Replacement: Schritt 4, Bild 2 von 2
    $3.99
    Kaufen
    • This is a good time to clean any accumulated dust or debris. Use this link on tips for cleaning.
    • Tool required: Tweezers
    • Carefully use tweezers to remove the audio jack connector from the motherboard.
Abschluss
DaisyHaskell
683 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team S1-G2, Valliere Fall 2018 Mitglied von UMass Dartmouth, Team S1-G2, Valliere Fall 2018
UMASSD-VALLIERE-F18S1G2
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 365
