Was du brauchst
Orient the laptop to have the back cover facing upwards.
Remove the four rubber pads located in each corner.
In diesem Schritt verwendetes Werkzeug:JIS Driver Set$19.99
Using the screwdriver, remove all of the exposed screws.
In diesem Schritt verwendetes Werkzeug:iFixit Opening Tool$1.99
Open the laptop and orient the keyboard facing upward.
Slowly wedge the opening tool into the gap between the keyboard and the back cover.
After loosening the back cover, close the laptop and orient the back cover facing upward. Open the cover.
In diesem Schritt verwendetes Werkzeug:Tweezers$3.99
Carefully use tweezers to remove the audio jack connector from the motherboard.
Use the JIS J1 screwdriver to remove the 6.5 mm screws surrounding the battery.
Using the iFixit tweezers, remove the cable connecting the battery to the motherboard.
Remove the wire located on the top side of the battery.
All connections should be removed. Simply remove the battery from the computer.
