Zum Hauptinhalt wechseln
HP Stream x360 11-p015wm Keyboard Replacement
Was du brauchst
  1. HP Stream x360 11-p015wm Keyboard Replacement, Back Cover: Schritt 1, Bild 1 von 2 HP Stream x360 11-p015wm Keyboard Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Orient the laptop to have the back cover facing upwards.
    • Remove the four rubber pads located in each corner.
  2. HP Stream x360 11-p015wm Keyboard Replacement: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    JIS Driver Set
    $19.99
    Kaufen
    • Tool required: JIS #1 Screwdriver
    • Using the screwdriver, remove all of the exposed screws.
  3. HP Stream x360 11-p015wm Keyboard Replacement: Schritt 3, Bild 1 von 2 HP Stream x360 11-p015wm Keyboard Replacement: Schritt 3, Bild 2 von 2
    iFixit Opening Tool
    $1.99
    Kaufen
    • Tool required: iFixit opening tool
    • Open the laptop and orient the keyboard facing upward.
    • Slowly wedge the opening tool into the gap between the keyboard and the back cover.
    • After loosening the back cover, close the laptop and orient the back cover facing upward. Open the cover.
  4. HP Stream x360 11-p015wm Keyboard Replacement: Schritt 4, Bild 1 von 2 HP Stream x360 11-p015wm Keyboard Replacement: Schritt 4, Bild 2 von 2
    $3.99
    Kaufen
    • This is a good time to clean any accumulated dust or debris. Use this link on tips for cleaning.
    • Tool required: Tweezers
    • Carefully use tweezers to remove the audio jack connector from the motherboard.
  5. HP Stream x360 11-p015wm Keyboard Replacement, Motherboard: Schritt 5, Bild 1 von 1
    • Remove the six 6.5 mm Phillips head screws from the battery using the JIS #00 screwdriver.
  6. HP Stream x360 11-p015wm Keyboard Replacement: Schritt 6, Bild 1 von 3 HP Stream x360 11-p015wm Keyboard Replacement: Schritt 6, Bild 2 von 3 HP Stream x360 11-p015wm Keyboard Replacement: Schritt 6, Bild 3 von 3
    • Unplug the wire attaching to the battery to the motherboard using the tweezers.
    • Remove the battery.
  7. HP Stream x360 11-p015wm Keyboard Replacement: Schritt 7, Bild 1 von 2 HP Stream x360 11-p015wm Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Remove the six 3.5 mm screws from the silver plate cover with screwdriver JIS #00.
    • Remove the silver plate cover.
  8. HP Stream x360 11-p015wm Keyboard Replacement: Schritt 8, Bild 1 von 2 HP Stream x360 11-p015wm Keyboard Replacement: Schritt 8, Bild 2 von 2
    • Remove the four 3.5 mm screws from the metal arm using the JIS #00 screwdriver.
  9. HP Stream x360 11-p015wm Keyboard Replacement: Schritt 9, Bild 1 von 3 HP Stream x360 11-p015wm Keyboard Replacement: Schritt 9, Bild 2 von 3 HP Stream x360 11-p015wm Keyboard Replacement: Schritt 9, Bild 3 von 3
    • Detach all remaining wires from the motherboard using the tweezers.
  10. HP Stream x360 11-p015wm Keyboard Replacement: Schritt 10, Bild 1 von 2 HP Stream x360 11-p015wm Keyboard Replacement: Schritt 10, Bild 2 von 2
  11. HP Stream x360 11-p015wm Keyboard Replacement: Schritt 11, Bild 1 von 2 HP Stream x360 11-p015wm Keyboard Replacement: Schritt 11, Bild 2 von 2
    • Remove the six 3.5 mm screws from the motherboard using the JIS #00 screwdriver.
    • Remove the motherboard.
  12. HP Stream x360 11-p015wm Keyboard Replacement, Keyboard: Schritt 12, Bild 1 von 2 HP Stream x360 11-p015wm Keyboard Replacement, Keyboard: Schritt 12, Bild 2 von 2
    • Remove the three 6.5 mm screws from the second screen hinge and metal arm using the JIS #00 screwdriver.
    • Remove the metal bracket.
  13. HP Stream x360 11-p015wm Keyboard Replacement: Schritt 13, Bild 1 von 1
    • Remove the two 3.5 mm screws from the small sideboard using the JIS #00 screwdriver.
  14. HP Stream x360 11-p015wm Keyboard Replacement: Schritt 14, Bild 1 von 2 HP Stream x360 11-p015wm Keyboard Replacement: Schritt 14, Bild 2 von 2
    • Use the blue plastic opening tool to pry up the silver keyboard cover.
    • Remove the keyboard cover.
  15. HP Stream x360 11-p015wm Keyboard Replacement: Schritt 15, Bild 1 von 2 HP Stream x360 11-p015wm Keyboard Replacement: Schritt 15, Bild 2 von 2
    • Remove the keyboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Megan Waxman
139 Reputation
1 Anleitung geschrieben
IUPUI, Team S2-G3, Stella Fall 2019 Mitglied von IUPUI, Team S2-G3, Stella Fall 2019
IUPUI-STELLA-F19S2G3
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 236
