Einleitung
If your keyboard has become damaged or broken, this guide will walk you through the steps of replacing the keyboard in an HP Stream x360 11-p015wm. Follow along, step-by-step to safely remove your keyboard and then follow the instruction in reverse to reassemble your laptop with its new keyboard! Be sure to back-up your files before undergoing this repair.
Was du brauchst
Orient the laptop to have the back cover facing upwards.
Remove the four rubber pads located in each corner.
Using the screwdriver, remove all of the exposed screws.
Open the laptop and orient the keyboard facing upward.
Slowly wedge the opening tool into the gap between the keyboard and the back cover.
After loosening the back cover, close the laptop and orient the back cover facing upward. Open the cover.
Carefully use tweezers to remove the audio jack connector from the motherboard.
Remove the six 6.5 mm Phillips head screws from the battery using the JIS #00 screwdriver.
Unplug the wire attaching to the battery to the motherboard using the tweezers.
Remove the battery.
Remove the six 3.5 mm screws from the silver plate cover with screwdriver JIS #00.
Remove the silver plate cover.
Remove the four 3.5 mm screws from the metal arm using the JIS #00 screwdriver.
Remove the six 3.5 mm screws from the motherboard using the JIS #00 screwdriver.
Remove the motherboard.
Remove the three 6.5 mm screws from the second screen hinge and metal arm using the JIS #00 screwdriver.
Remove the metal bracket.
Remove the two 3.5 mm screws from the small sideboard using the JIS #00 screwdriver.
Use the blue plastic opening tool to pry up the silver keyboard cover.
Remove the keyboard cover.
Eine weitere Person hat diese Anleitung absolviert.
