Einleitung
Use this guide to replace a broken camera.
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
In the following steps, you will use a metal spudger to lift the front panel out from the rear case of your TouchPad.
Insert a flat metal spudger in the gap between the rubber outer ring on the front panel assembly and the black plastic rear case near the USB connector.
Pry the front panel assembly up from the rear case, being careful not to damage the LCD or the glass panel.
As in the previous step, use a spudger to pry the front panel up from the rear case along its long edge on the volume button side of the TouchPad.
Continue to pry the front panel assembly up along the volume button side of the TouchPad until there is a gap between it and the rear case.
Before lifting the free side of the front panel up from the rear case, you may need to release it from the plastic retaining clips holding it down.
Use your metal spudger to pull the stuck retaining clips away from the edge of the front panel.
After freeing the retaining clips, lift the front panel assembly away from the rear case.
Use the attached black tab to pull the display data cable straight up and out of its socket on the motherboard.
Use your fingernail to carefully flip up the retaining flaps on the two digitizer ribbon cable ZIF sockets.
Pull the digitizer ribbon cable straight out of its two sockets on the motherboard.
Use a plastic opening tool to pry the camera connector up and out of its socket on the motherboard.
Wedge a plastic opening tool underneath the camera and carefully pry upwards to dislodge it from its recess in the rear case.
Lift the camera out of the rear case.
