Zum Hauptinhalt wechseln
HP TouchSmart 15-r015dx Keyboard Replacement
Was du brauchst
  1. HP TouchSmart 15-r015dx Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 2 HP TouchSmart 15-r015dx Keyboard Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Using your Phillips #00 screwdriver, remove the two screws to loosen the fittings of the keyboard.
    • One of the screws lies in the label.
  2. HP TouchSmart 15-r015dx Keyboard Replacement: Schritt 2, Bild 1 von 3 HP TouchSmart 15-r015dx Keyboard Replacement: Schritt 2, Bild 2 von 3 HP TouchSmart 15-r015dx Keyboard Replacement: Schritt 2, Bild 3 von 3
    • Flip the laptop over to view the top and lift the screen up.
    • There are sixteen clips holding the keyboard in place. Gently pry up each clip using a plastic opening tool. Once all clips are loose, lift the keyboard from the computer.
    • Do NOT pull the keyboard up more than 2-3 inches as there is a film-material connecting the keyboard to the laptop.
  3. HP TouchSmart 15-r015dx Keyboard Replacement: Schritt 3, Bild 1 von 3 HP TouchSmart 15-r015dx Keyboard Replacement: Schritt 3, Bild 2 von 3 HP TouchSmart 15-r015dx Keyboard Replacement: Schritt 3, Bild 3 von 3
    • There is a small black latch holding the film-material in place.
    • Flip the black latch up to release the film-material. Once flipped up, simply pull the film-material out from the laptop to release the keyboard.
    • There are tiny prongs on the ribbon; it must be carefully removed and upon re-installation the prongs must be lined up exactly in each tiny track in order for the keyboard to work.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 16-4, Watkins Winter 2015 Mitglied von USF Tampa, Team 16-4, Watkins Winter 2015
USFT-WATKINS-W15S16G4
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 23
Insgesamt: 3,063
