Einleitung
Use this guide to lead in the replacement of your HP TouchSmart 15 screen.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Acquire the metal spudger and a Precision Magnetized Driver with J1 size bit.
    • Acquire the metal spudger and a Precision Magnetized Driver with J1 size bit.
    • Flip your HP TouchSmart 15 over.
  2. Locate tabs on the underside of the laptop.
    • Locate tabs on the underside of the laptop.
    • Push both tabs towards the center of the laptop and pull away to remove battery.
    • Take the sharp end of the pry tool and pop out the black screw cover.
    • Repeat on opposite side.
    • Take the Precision Magnetized Driver with J1 size bit and unscrew the screw.
    • Using the pry tool, begin to separate the touchscreen from the plastic backing.
    • Close the laptop and flip it over once again.
    • Continue to pry the touchscreen from the plastic backing in the hinged area of the laptop.
    • Flip over the laptop and open it.
    • Pull up on the separated touchscreen while pulling it away from the plastic backing.
      • Be careful while laying down the touchscreen to not pull the connection point.
    • Lay the touchscreen on the keyboard facedown.
    • Locate the connection point.
    • Slowly and carefully peel off.
    • Isolate the touchscreen from the keyboard.
    • Begin by peeling off the black adhesive tape using the pry tool.
    • Once adhesive tape is removed, use the pry tool to remove the tab in the corner. Repeat in each corner.
    • Using the sharp end of the pry tool, separate the plastic from the screen.
    • Now it is time to reassemble your device with a new screen.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Gabriel Terrasas
Mitglied seit 30.11.2017
241 Reputation
1 Anleitung geschrieben
Amazing work. I would not change a thing.
Dan Hartzell - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 21
Insgesamt: 368
