Zum Hauptinhalt wechseln
HP TouchSmart 15-r015dx Screen Replacement
Was du brauchst
  1. HP TouchSmart 15-r015dx Screen Replacement, Screen: Schritt 1, Bild 1 von 3 HP TouchSmart 15-r015dx Screen Replacement, Screen: Schritt 1, Bild 2 von 3 HP TouchSmart 15-r015dx Screen Replacement, Screen: Schritt 1, Bild 3 von 3
    • Acquire the metal spudger and a Precision Magnetized Driver with J1 size bit.
    • Flip your HP TouchSmart 15 over.
  2. HP TouchSmart 15-r015dx Screen Replacement: Schritt 2, Bild 1 von 3 HP TouchSmart 15-r015dx Screen Replacement: Schritt 2, Bild 2 von 3 HP TouchSmart 15-r015dx Screen Replacement: Schritt 2, Bild 3 von 3
    • Locate tabs on the underside of the laptop.
    • Push both tabs towards the center of the laptop and pull away to remove battery.
  3. HP TouchSmart 15-r015dx Screen Replacement: Schritt 3, Bild 1 von 3 HP TouchSmart 15-r015dx Screen Replacement: Schritt 3, Bild 2 von 3 HP TouchSmart 15-r015dx Screen Replacement: Schritt 3, Bild 3 von 3
    • Take the sharp end of the pry tool and pop out the black screw cover.
    • Repeat on opposite side.
  4. HP TouchSmart 15-r015dx Screen Replacement: Schritt 4, Bild 1 von 3 HP TouchSmart 15-r015dx Screen Replacement: Schritt 4, Bild 2 von 3 HP TouchSmart 15-r015dx Screen Replacement: Schritt 4, Bild 3 von 3
    • Take the Precision Magnetized Driver with J1 size bit and unscrew the screw.
  5. HP TouchSmart 15-r015dx Screen Replacement: Schritt 5, Bild 1 von 3 HP TouchSmart 15-r015dx Screen Replacement: Schritt 5, Bild 2 von 3 HP TouchSmart 15-r015dx Screen Replacement: Schritt 5, Bild 3 von 3
    • Using the pry tool, begin to separate the touchscreen from the plastic backing.
  6. HP TouchSmart 15-r015dx Screen Replacement: Schritt 6, Bild 1 von 3 HP TouchSmart 15-r015dx Screen Replacement: Schritt 6, Bild 2 von 3 HP TouchSmart 15-r015dx Screen Replacement: Schritt 6, Bild 3 von 3
    • Close the laptop and flip it over once again.
    • Continue to pry the touchscreen from the plastic backing in the hinged area of the laptop.
  7. HP TouchSmart 15-r015dx Screen Replacement: Schritt 7, Bild 1 von 3 HP TouchSmart 15-r015dx Screen Replacement: Schritt 7, Bild 2 von 3 HP TouchSmart 15-r015dx Screen Replacement: Schritt 7, Bild 3 von 3
    • Flip over the laptop and open it.
    • Pull up on the separated touchscreen while pulling it away from the plastic backing.
    • Be careful while laying down the touchscreen to not pull the connection point.
    • Lay the touchscreen on the keyboard facedown.
  8. HP TouchSmart 15-r015dx Screen Replacement: Schritt 8, Bild 1 von 3 HP TouchSmart 15-r015dx Screen Replacement: Schritt 8, Bild 2 von 3 HP TouchSmart 15-r015dx Screen Replacement: Schritt 8, Bild 3 von 3
    • Locate the connection point.
    • Slowly and carefully peel off.
  9. HP TouchSmart 15-r015dx Screen Replacement: Schritt 9, Bild 1 von 2 HP TouchSmart 15-r015dx Screen Replacement: Schritt 9, Bild 2 von 2
    • Isolate the touchscreen from the keyboard.
  10. HP TouchSmart 15-r015dx Screen Replacement: Schritt 10, Bild 1 von 3 HP TouchSmart 15-r015dx Screen Replacement: Schritt 10, Bild 2 von 3 HP TouchSmart 15-r015dx Screen Replacement: Schritt 10, Bild 3 von 3
    • Begin by peeling off the black adhesive tape using the pry tool.
    • Once adhesive tape is removed, use the pry tool to remove the tab in the corner. Repeat in each corner.
  11. HP TouchSmart 15-r015dx Screen Replacement: Schritt 11, Bild 1 von 3 HP TouchSmart 15-r015dx Screen Replacement: Schritt 11, Bild 2 von 3 HP TouchSmart 15-r015dx Screen Replacement: Schritt 11, Bild 3 von 3
    • Using the sharp end of the pry tool, separate the plastic from the screen.
  12. HP TouchSmart 15-r015dx Screen Replacement: Schritt 12, Bild 1 von 1
    • Now it is time to reassemble your device with a new screen.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
Amazing work. I would not change a thing.
Dan Hartzell - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,241
