Einleitung
Webcams can be damaged very easily, but luckily they are also easy to replace. Please only use this guide after trying some troubleshooting steps on your computer, you don't want to open up your laptop if it is not necessary. You can troubleshoot by re-starting it, updating software, or rebooting it. If your camera still doesn't work, go ahead with executing these steps.
Was du brauchst
Use the black nylon spudger to separate the front frame and the back cover of the laptop. Start at the top and work your way around the screen.
After creating space between the back cover and the front frame, use your hands to slowly open the frame. Follow the images to get clear idea.
