Einleitung
This guide goes over how to replace the controller's main circuit board.
If your TPC-Q044 circuit board starts failing when using your controller, you may want to think about replacing the component. The failure may be a result of bad soldering or missed connections. The replacement of the circuit board is not too complex. A couple of screwdrivers and a spudger will be sufficient to complete this task. There are no warnings or potential hazards when replacing the board.
Was du brauchst
Grip the main body and pull the joystick outwards until the entire front panel pops off.
Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
Use a spudger to pry apart the two halves of the assembly.
Work slowly, prying a small section at a time until the halves are completely separated.
Using a Phillips #00 screwdriver, remove the four 4mm screws located on the joystick circuit board underneath the top half of the controller.
Remove the orange flat cable by pulling the orange tab parallel to the circuit board.
Release the blue flat cable by lifting up the white latch with a spudger.
Remove the two 6mm screws at the base of the ring using a Phillips #0 screwdriver.
Pull towards the base of the controller to release the black wire from the connector on the circuit board.
Pull the ring apart from the rest of the controller.
Remove the two 3mm screws on the V-clip using a Phillips #00 screwdriver.
Remove the V-clip from the device.
With the V-clip off of the controller, use a Phillips #00 screwdriver to remove the remaining 4mm screw.
Remove the circuit board.
4 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Awesome! But were do you get the components to replace from??
Since separate controllers are very difficult to find and expensive (You wont find Samsung ones) I will be interested to buy a few to do repairs to friends and so.
