Zum Hauptinhalt wechseln
HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement
Was du brauchst
  1. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Batteries: Schritt 1, Bild 1 von 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Batteries: Schritt 1, Bild 2 von 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Batteries: Schritt 1, Bild 3 von 3
    • Slide the rear compartment cover in the direction of the arrow.
    • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
  2. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Shell: Schritt 2, Bild 1 von 2 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Shell: Schritt 2, Bild 2 von 2
    • Remove the four 4mm screws using a Phillips #00 screwdriver.
  3. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: Schritt 3, Bild 1 von 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: Schritt 3, Bild 2 von 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: Schritt 3, Bild 3 von 3
    • Grip the main body and pull the joystick outwards until the entire front panel pops off.
    • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
  4. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: Schritt 4, Bild 1 von 2 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: Schritt 4, Bild 2 von 2
    • Use a spudger to pry apart the two halves of the assembly.
    • Work slowly, prying a small section at a time until the halves are completely separated.
  5. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Small Circuit Board: Schritt 5, Bild 1 von 2 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Small Circuit Board: Schritt 5, Bild 2 von 2
    • Using a Phillips #00 screwdriver, remove the four 4mm screws located on the joystick circuit board underneath the top half of the controller.
  6. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: Schritt 6, Bild 1 von 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: Schritt 6, Bild 2 von 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: Schritt 6, Bild 3 von 3
    • Remove the orange flat cable by pulling the orange tab parallel to the circuit board.
    • Release the blue flat cable by lifting up the white latch with a spudger.
  7. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Main Circuit Board: Schritt 7, Bild 1 von 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Main Circuit Board: Schritt 7, Bild 2 von 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Main Circuit Board: Schritt 7, Bild 3 von 3
    • Remove the two 6mm screws at the base of the ring using a Phillips #0 screwdriver.
    • Pull towards the base of the controller to release the black wire from the connector on the circuit board.
    • Pull the ring apart from the rest of the controller.
  8. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: Schritt 8, Bild 1 von 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: Schritt 8, Bild 2 von 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: Schritt 8, Bild 3 von 3
    • Remove the two 3mm screws on the V-clip using a Phillips #00 screwdriver.
    • Remove the V-clip from the device.
  9. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: Schritt 9, Bild 1 von 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: Schritt 9, Bild 2 von 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: Schritt 9, Bild 3 von 3
    • With the V-clip off of the controller, use a Phillips #00 screwdriver to remove the remaining 4mm screw.
    • Remove the circuit board.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Eeshan Mishra
424 Reputation
4 Anleitungen geschrieben
Cal Poly, Team S1-G2, Maness Spring 2019 Mitglied von Cal Poly, Team S1-G2, Maness Spring 2019
CPSU-MANESS-S19S1G2
4 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
Awesome! But were do you get the components to replace from??
Since separate controllers are very difficult to find and expensive (You wont find Samsung ones) I will be interested to buy a few to do repairs to friends and so.
Baba Nam Kevalam - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 21
Insgesamt: 1,889
