Zum Hauptinhalt wechseln
HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement
Was du brauchst
  1. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: Schritt 1, Bild 1 von 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: Schritt 1, Bild 2 von 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: Schritt 1, Bild 3 von 3
    • Slide the rear compartment cover in the direction of the arrow.
    • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
  2. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Shell: Schritt 2, Bild 1 von 2 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Shell: Schritt 2, Bild 2 von 2
    • Remove the four 4mm screws using a Phillips #00 screwdriver.
  3. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: Schritt 3, Bild 1 von 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: Schritt 3, Bild 2 von 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: Schritt 3, Bild 3 von 3
    • Grip the main body and pull the joystick outwards until the entire front panel pops off.
    • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
  4. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: Schritt 4, Bild 1 von 2 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: Schritt 4, Bild 2 von 2
    • Use a spudger to pry apart the two halves of the assembly.
    • Work slowly, prying a small section at a time until the halves are completely separated.
  5. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: Schritt 5, Bild 1 von 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: Schritt 5, Bild 2 von 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: Schritt 5, Bild 3 von 3
    • Grasp the trigger with one hand while pushing against the outer wall of the shell.
    • Apply pressure, pulling the wall away from the trigger.
    • Remove the trigger starting from the freed edge.
    • The spring-rod assembly can easily come apart. Inserting the large end first during reassembly may make the process easier.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team S18-G5, White Winter 2019 Mitglied von Cal Poly, Team S18-G5, White Winter 2019
CPSU-WHITE-W19S18G5
2 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 18
Insgesamt: 1,613
