Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Here is some information about what to do if your computer gives you a message saying "Low Disk Space." If you turn on your computer and it won't boot properly, read this troubleshooting guide. If you determine that you need to replace or upgrade your hard drive, follow this replacement guide!
  1. Flip the laptop over. Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
  2. Slide the right lever firmly to the right.
    • Slide the right lever firmly to the right.
    • Slide the cover towards yourself to remove it.
  3. EINFACH ALLE TABS ÖFFNEN
    RAM Upgrade Kits für Mac
    Kits kaufen
    Genügend RAM
    für alle Tabs
    Kits kaufen
  4. Unscrew the three captive screws holding the drive in place with a Phillips #0 screwdriver.
    • Unscrew the three captive screws holding the drive in place with a Phillips #0 screwdriver.
    • The screws will remain inside the springs of the hard drive caddy cover.
  5. Pull the green tab away from the metal casing and lift the drive out. Pull the green tab away from the metal casing and lift the drive out.
    • Pull the green tab away from the metal casing and lift the drive out.
  6. Remove the two 3mm screws on either side of the device with a Phillips #0 screwdriver to remove the drive caddy.
    • Remove the two 3mm screws on either side of the device with a Phillips #0 screwdriver to remove the drive caddy.
Abschluss
9 weitere Nutzer haben diese Anleitung absolviert.
Grant Terris
2.393 Reputation
12 Anleitungen geschrieben
Cal Poly, Team 8-43, Amido Winter 2015 Mitglied von Cal Poly, Team 8-43, Amido Winter 2015
CPSU-AMIDO-W15S8G43
4 Mitglieder
15 Anleitungen geschrieben
You can use Macrium Reflect (there's a free non-commercial version) to backup your disk to an external drive before swapping the drive.
Paul M - Antwort
There is written 'SSD' on its cover, and I'm confused now. Actually I need to disconnect the HDD and then install new OS on the SSD, and now I'm not sure if the drive that you just removed is SSD or HDD because on mine it say SSD. Please help me out.
Sajid - Antwort
how hard disk i can buy for my zbook 15?
thanks
francesco perego - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 3
Letzten 7 Tage: 55
Letzten 30 Tage: 304
Insgesamt: 19,860
