Einleitung
If the CD/DVD drive on your computer is broken and needs replacing, follow this replacement guide!
Was du brauchst
Flip the laptop over.
Slide the lever with the battery symbol beside it firmly until the battery pops out.
Remove the battery from the laptop.
Slide the right lever firmly to the right.
Slide the cover towards yourself to remove it.
Unscrew the captive screw shown near the battery compartment with a Phillips #0 screwdriver.
Push outward on the metal optical drive tab with a metal spudger to unlock the drive from its position in the case.
Once the drive is protruding from the side of the computer, pull it the rest of the way out.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Oddly enough, mine came with no DVD drive but a blanking… thing, which seems to be a trimmed-down version of this official adapter (HP SPS 734298-001) without the electronics. I bought a cheap chinese ODD caddy, tore it down and salvaged the logic board. Luckily, I got everything lined up after a few adjustments (the chinese logic board is a bit longer than the HP one).
Now I’m rocking an extra drive bay without paying the $75 some shops ask for the official one.
I use it as swappable storage (not hot-swappable, mind you) . Very handy for doing drive imaging and cloning when working as an IT technician out in the field.
