Einleitung
If your HP Zbook 15u G2 does not hold a charge, or the battery does not last as long as it did before, you can replace the battery with a new one. This guide shows you how to replace the battery.
Was du brauchst
Turn the HP Zbook over and flip the switch at the top so the red part is visible.
Lift the plastic tab at the top of the battery up to lift the battery up and out of the device
Fast fertig!
Abschluss
